JSA Posted 15 juni 2003 Report Share Posted 15 juni 2003 Ik las het volgende op deze site: The KSA-100S is built up from the KSA-150, but with an S-series powersaving feature. The S series has 5 Biasing levels that is managed by the Anticipator circuit. The Anticipator circuit senses the incoming signals demand and lightning fast rises the Bias after the needs. It will make sure the amplifier is always operating in pure class A. When the demande parameters has been lower than the Biasing level bing used the amplifier will fall back to the next lower Bias level within 30seconds or so. This kind of operation with the Anticipator is an invention by Krell and called Sustained Plateuau Biasing. The Anticipator circuit is many times faster than the amplifier it self. On each power amplifier drivestage PCB there is a switch marked "BIAS". It has two configurations "Relaxed" or "Normal". It shall be in "Normal" to use the amplifier in class A. In the "Relaxed" mode the amplfier is only operating in class AB, thus getting better efficency for people who has poor AC outlets. Though the amplifier utilieses the Anticipator it will get above the 25% effiency border. As an example an ordinary class AB has 35-48% effiency. Weet iemand of er ook andere Krells zijn dan de 100s die een bias switch hebben? Link to comment Share on other sites More sharing options...
Sebastiaan de vries Posted 15 juni 2003 Report Share Posted 15 juni 2003 Beste Jasper, De KSA 250-EUR was de eerste krell met 3 biasstanden. Daarna kwam de KSA-S serie. Het probleem van het eerste generatie Sustained plateuau Bias, is dat deze geen rekening houdt met de impedantie vand e weergever. Vanaf de FPB serie wordt zowel de in, als de uitgang gemonitord, in tegenstelling tot de KSA-S serie. Groeten, Bas Link to comment Share on other sites More sharing options...
JSA Posted 15 juni 2003 Author Report Share Posted 15 juni 2003 Beste Bas, Hier hebben ze het volgens mij over een echte bias schakelaar ergens op de printplaat met twee standen, relax & normal. Weet jij zo of de KSA300S en de KAS ook van die schakelaars hebben? Link to comment Share on other sites More sharing options...
Sebastiaan de vries Posted 15 juni 2003 Report Share Posted 15 juni 2003 Beste Jasper, Oh sorry, heb weer niet goed gelezen. Je bedoelt de interne switch. Ik heb daar ook geen idee van, en ook ik weet het alleen van de X00-S serie. Of de KAS dat ook heeft weet ik niet. Denk waarschijnlijk van niet, want als je een KAS kan betalen, kun je ook de stroom rekening betalen . Maar serieus, stuur eens een mailtje naar Krell Amerika. Krijg je altijd binnen 2 dagen een duidelijk antwoord, weet je alles. Groeten, Bas Link to comment Share on other sites More sharing options...
JSA Posted 15 juni 2003 Author Report Share Posted 15 juni 2003 Nouja, het is wel lullig als je de stroomrekening wel kan betalen en je eindtrap heeft al die tijd op Relax gestaan, omdat je er niks van afwist thanks anyway Mailtje is onderweg, ben benieuwd Link to comment Share on other sites More sharing options...
SpeedyAndr Posted 15 juni 2003 Report Share Posted 15 juni 2003 Geplaatst door Sherwin:Vanwaar al die interesse Jasper? Je hebt pas een nieuwe versterker! Mvgr Ik heb Jasper besmet zeker Andr Link to comment Share on other sites More sharing options...
