jepe Posted 19 november 2004 Report Share Posted 19 november 2004 Beste kenners, Wat vinden jullie van onderstaand verhaal. Het klinkt aardig maar klopt het? Heeft iemand er ervaring mee? 'What is DVD+Audio? DVD+Audio is a DVD-Video compliant format, wich means that your normal standalone DVD player can play the DVD+Audio discs, no need to buy expensive new hardware. You can create a disc containing multiple albums, compiled from your own normal CD-Audio disc, but then in either high quality (up to PCM 96kHz/24bits) or high quantity (up to 45 hours MP2 at 192kbps) audio to any DVD player. Please note : DVD+Audio should not be confused with DVD-Audio, for which you need a special player and discs! How does this magic work? The heart of the program consists of two engines: Extremely precise sample rate convertor. Resamples 44.1kHz CD-Audio to the 48kHz or 96kHz used on DVD. Revolutionary resolution enhancement. Extends the 16 bit used on CD to the DVD compliant 24 bits. Combining both engines, a DVD+Audio easily surpasses CD quality, and in the resulting sounds you can enjoy better imaging, clearer detail, deeper and tighter bass and a overal better sound experience. Unlike other resamplers, that base their processing on mathematical functions (for instance bessel), our processing is based on musical information and the knowledge that the original master contains more detail than the CD. Therefor when you analyse the resulting waveforms using conventional methods, the measurements may be different than you expect. The only proper way to test it is with your ears, not with your eyes. Technical details Supported input formats: Wave files 2 channels 44.1/48/96 kHz, 16/24/32 bits MP3 files, CBR and VBR, 32-320 kbps Supported output formats: PCM 48/96 kHz, 16/20/24 bits MP1 48kHz 320/352/384/416/448 kbps MP2 48kHz 192/224/256/320/384 kbps Notes: Currently there is no upsampling from 48 to 96 kHz, only from 44.1 to 48 and 96. Currently there is no resolution enhancement from 16 to 24 bits for 48 and 96 kHz, only for 44.1 kHz. DVD+Audio is not just any audio dithering or upsampling application, but a true revolution in sound processing! But don't believe us, believe your own ears by downloading the trial version and convert some of your own favourite tracks into this new exciting format! To obtain the real experience make sure that, the input wavefiles are grabbed directly from the original CD, not from a compressed source like MP3! ' Link to comment Share on other sites More sharing options...
Sodejuu Posted 20 november 2004 Report Share Posted 20 november 2004 Dit is al eens aan bod geweest TOPIC Link to comment Share on other sites More sharing options...
